Vacuum diagram needed, already searchedDevilmotorsports 02-26-2003, 12:18 PM I need a vacuum diagram for an 85 Civic 1.5L carb'd, My under hood diagram is messed up and I've got to do some work on it. Thanks, Chris earthsheartbeat 04-16-2003, 10:38 AM I found my vacuum diagram at the local library. Los Altos, CA to be exact. They and many other library's around the country have database access to ALLDATA PRO. The license requires that you go to the library instead of using remote web access. You might go to the ALLDATA website and see if they have a list of licensed libraries in your area. This is all I needed to replace my timing belt, water pump, and adjust my valves and I am a major rookie. Automotive Network, Inc., Copyright ©2012
