bumpersHeWhoKillz 03-08-2008, 04:45 AM I decided before I get any ground effects, I thought I would figure out how to take the bumpers off. Its a 91 corolla. I have a haynes book on it but they aren't very graphic. How many bolts hold in a bumper? It talks about the retention bolts too. khooper 03-11-2008, 10:59 PM I had to replace mine as well. It was so easy. 1= open the boot 2= pull back the carpet 3= remove the plastic panels from the lights (makes it easier to get to) 4= behind each rear litht you will see two bolds one in front of the other like this ___:_| ( line on bottom= rear of boot where lights are, line on the side= side of boot, := the two bolts) 5= you can loosen the 2 bolts on both sides to adjust the bumper, or remove the bolts so you can remove the bumper. One the bolts are removed the bumper will not fall off. It is still held on by the brackets. At the back of each wheel arch there may be some screws attaching the bumper to the cover under the wheel arch. Remove the screws and slide the bumper back. 6= installation is the reversal See how you go:runaround: ----- Leave sooner, drive slower, live longer. Check your auto body parts (http://www.autopartswarehouse.com) regularly. HeWhoKillz 03-13-2008, 08:28 PM Boot? Carpet? Please, do explain this. I dont know what you mean by boot, and I didn't know there was carpet in bumpers, since I have never taken them apart before. Automotive Network, Inc., Copyright ©2012
