SOHC to DOHC conversion?
e_a_olson
02-26-2003, 08:18 AM
Can an engine be converted from SOHC to DOHC? What would need to be replaced in addition to the cams themselves? Thanks.
ivymike1031
02-26-2003, 08:21 AM
the head(s), perhaps the timing drive tensioner, etc.
e_a_olson
02-26-2003, 08:34 AM
Would it be more cost effective to convert an engine I already own (Subaru EJ25 SOHC) to DOHC, or buy a new EJ25 DOHC.
ales
02-26-2003, 10:07 AM
Definitely get a new (another) engine, as things in it are designed to work together and you won't have to replace anything. And also can do a good rebuild of the engine going into the car while you're at it! :)
SaabJohan
02-27-2003, 04:25 AM
Car manufacturers does sometimes make DOHC and SOHC versions of the same engine. Maybe you can just replace the cylinderhead, but if you're unlucky pistons and so on might also be diffrent. In that case it's probably better to buy a DOHC engine.
