New Spark Plugs
Kid_Buick_98&84
03-05-2008, 06:44 AM
Ok Its time for new plugs in my '05 Grand Am. This is the first time I've done this myself on this car. So any help would be appreciated such as gap size and what is the best spark plug to use, i want to get the best ones i can that actually help. Ive been checking them out and there are many options and i just want to know what would be best.
Thanks!:popcorn:
Kid_Buick_98&84
03-05-2008, 06:54 AM
Oh yeah and is there any difference between all the plug wires? What ones would be best?
Also on an unrealted note ive heard that grand ams hvs a weak alternator is this a myth or is there something to it if so should i worry at this point the car is only an 05.
Thanks!
Jmoney3318
03-05-2008, 08:48 AM
yea the grand ams alt. is garbage ive been through 2 already, best to go to mralternator.com they got sum nice alternators their and plus they do powder coating and about your spark plug problem cant really help there im in the same boat as you as to what kind to get i just hit my 50xxx miles on my car so i wanna start to do maintenance shit
Headnsouth
03-05-2008, 08:55 AM
Go with OEM plugs which are prolly AC's. I'd use those or NGK's. Do not use Bosch platinums.
Can't tell you much about wires the prices range from here to there. Buy a brand name with a lifetime warranty.
xeroinfinity
03-05-2008, 09:42 AM
AC Iridiums are what GM recommends, about $6 each.
Good wires are hard to come by, Taylor spiro wires are good.
If you look in the OEM & Performance parts (http://www.automotiveforums.com/vbulletin/showthread.php?t=502706) thread you'll find bunches of links for parts. :thumbsup:
Good Hunting
Gir-_-
03-05-2008, 12:59 PM
Good Hunting
ya the AC Delco Iridium Plugs are nice! :iceslolan
the Taylor spiro pro 8mm wires can be found online if you'd like to go that route - pfyc.com - under grand am section -> under the hood
i use both of those, if you wanna take it a step further you can also get MSD Ignition coil packs for your GA as well - just ask if you want more info, ill provide the link and or you may be able to pick them up at a local auto store
I assume you have a v6?
Kid_Buick_98&84
03-07-2008, 03:19 PM
Yeah its the 3400 V6.
Yeah id like more info on the coil packs:evillol:
Gir-_-
03-07-2008, 05:37 PM
http://www.shopatron.com/product/product_id=MSD8224/424.0
right here sir! :D
they're $45 each, times that by 3 plus shipping, it comes out to like $160 or so, thats not bad IMO for some replacement GOOD aftermarket coils, it took me 30mins tops to replace them (had to work around my front strut bar in the engine bay, didnt want to take it all off lol), also what I did was use a sharpie for each one and labeled mine for future reference... I put them on and noticed little better power and gas mileage, the idle smoothed a bit as well.. but def worth buying for terms of reliability!
if you wanna find em locally, you could possibly check autozone or advance auto parts ...
the name/part# is: GM 2-Tower Coil Pack, PN 8224
good luck!
ps, i'd recommend ac delco iridiums for spark plugs for these coils, due to the hotter more potent spark... the iridium metal would be more than enough to hold the coils power
When it comes to late model performance parts, nothing beats bolt-on and direct connection components. Especially when they improve performance with a hotter spark like these new MSD Blaster Coils. These new bolt-in coils are designed with improved materials and windings to produce a stronger spark. This improved spark helps burn the fuel mixture more efficiently resulting in a smooth idle and improved mid range rpm power.
edit:
ps, on top of that, ive also purchased a new ICM - Ignition Control Module, made by duralast for the grand am, not the greatest brand IMO but it was what I needed at the time to fix my car =/
Kid_Buick_98&84
03-14-2008, 01:54 AM
Good Hunting
Well I have the Plugs and Wires in and the car runs good, it smoothed out the idle.
Next step...Coil Packs
Thanks For everyone's input!!!:grinyes:
wafrederick
03-14-2008, 09:30 PM
Carquest also makes great plugwires,the top of the line ones with a lifetime warranty.AC Delco plugwires Are grest too,I heard this too.Change the fuel filter also,part of a tune up and this is the mostly neglected part since it is underneath the car.If it is not changed,gets plugged up and puts a strain on the fuel pump burning it up.
