Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Subaru > Legacy / Liberty / Baja
Old 03-04-2008, 09:02 AM   #1
richardGear
richardGear Normal reputation
Subaru Legacy 95 Keyless Remote
Can someone help with instructions on how to program this Keyless remote thing. It would be of great help to me.
Thanks
richardGear is offline   Reply With Quote
Old 06-22-2008, 09:08 PM   #2
EddieAtTheMorgue
EddieAtTheMorgue Normal reputation
Re: Subaru Legacy 95 Keyless Remote
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (button under dashboard, see below*)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
*Code Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
EddieAtTheMorgue is offline   Reply With Quote
Bookmarks
Google
Web AF
