My speed gauge dont workscooter1989 03-03-2008, 03:04 AM my speed gause comes on and of all the time but never stays on what is the problem jeffcoslacker 03-03-2008, 07:17 AM Model year? Do you have cruise control? Does it work? scooter1989 03-05-2008, 03:08 AM 91 accord and no the cruise does not work somick 03-05-2008, 12:46 PM 91 accord and no the cruise does not work Do a search for VSS. This is most likely your problem. We have had couple of threads recently on the forum. Good luck, Sam edit: VSS stands for vehicle speed sensor wiseguy01 03-05-2008, 03:05 PM do you have a check engine light on?? if so its more than likely vss like somick said... i recently went throught the same problem it ended up being a loose corroded connection on the vss pigtail and mine is a 93 jeffcoslacker 03-05-2008, 05:53 PM Yeah if the cruise quit the same time as the speedo, I'd vote the VSS is at fault too...that's where I was going with that question... Automotive Network, Inc., Copyright ©2012
