obd II port dead
therigwelder
02-28-2008, 10:03 PM
i own an 02 silverado 2500 the service engine light soon has been lit for several weeks now i finally got around to hooking my scan tool up to pull codes well i plugged the scanner in and nothing happened no power was coming from the vehicle connecter i tested my scanner on another vehicle to confirm it was working and it was.now i need some help troubleshooting the faulty obd II port on the truck
2000CAYukon
02-29-2008, 12:10 AM
Does the cigarette lighter work? The OBD-II port shares the same fuse.
//2000CAYukon
therigwelder
02-29-2008, 07:39 PM
well i have 3 12v outlets 2 of them work all fuses are good
MT-2500
03-01-2008, 10:43 AM
http://www.troublecodes.net/OBD2/
Check for ground on pin 4-5
Check for 12 volt battery power on pin 16
Bob B
03-02-2008, 11:38 AM
When my obd11 port was dead, so was the lighter socket.
It was the fuse.
Meter the fuse or swap it. They might look good but be bad
Bob B
J-Ri
03-03-2008, 05:59 PM
:iagree:
I'd bet the one lighter that doesn't work shares power with the DLC. Either a fuse or an open wire. If you don't care about keeping the wiring factory, just cut the power wire a few inches away from the connector (to leave room to re-connect if you ever decide to fix it) and run a jumper wire from it to the battery or another lighter when you want to check codes. It doesn't go to any computers at all, it just provides power for a scan tool.
