Re: No blue Highbeam Dash Indicator.
I imagine the bulb is out on the high beam indicator, If you've got the original clutch in a truck with that many miles I'm sure You need a clutch pressure plate and throw out bearing and on thiis model you would want to replace the clutch master and slave cylinder when the rest is replaced because the tranmission has to be pulled to get to the slave cylinder. you'll also want new fluid in the transmission when all this gets done
