| How-To's and Walk-Through's Here's where we show you how it's done! |
02-25-2008, 08:30 PM
crx help
ok.i have a 91 crx hf with the 1.5 d15b6 engine.im am swaping in a 88 si d16a6 engine.i was told i have to swap the ecu but i dont know how.can anyone help.
02-26-2008, 03:15 AM
Re: crx help
your ecu is located under the passenger side carpet where they rest their feet. under the glove box. just pull back the carpet and there should be a plate with 3 nuts holding it and your ecu is underneath. simple plug and play..
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
02-26-2008, 08:30 AM
Kind of a Big Deal
Re: crx help
So you now how to install an engine.. but not plug in an ECU? no offense... but it sounds like you need to do some more research
02-26-2008, 11:50 AM
Re: crx help
oh to be a noob again..at least hes not tryin to go k series lol..
02-26-2008, 02:35 PM
Re: crx help
just didnt know if the wire plugins were the same or not.also and who cares if im makeing myself look dumb but anyway.on the firewall on the passenger side there is a box whitch on the 88 si says pm6. the caccume lines go to the intake and the round thing under neith it,do i need to swap these or will the box that is on the 91 hf work? the wire plugins are different is the only reason im asking.oh yea thanks for all the help
02-26-2008, 02:41 PM
Re: crx help
one more thing.once i get the si engine in what can i do to give it more power and alittle better fuel millage?
02-26-2008, 02:53 PM
Kind of a Big Deal
Re: crx help
My only point was that it take serious mechanical knowlege to do a motor swap... and if you werent sure if the 2 ECU's would use the same plug, you may want to do some more research before you do this swap as it wont take much to be in over your head and youre stuck without a car because you already started pulling the old motor.
And yes the new ECU will plug into the exsisting harness. but you may have to swap some pins to get it to run right.
And the box I THINK youre talking about is a charcoal canister... and you can either use the exsisting one, or the 91 one
(If anything i said wasnt completly true its cuz im not really a 4th gen guy)
02-26-2008, 08:00 PM
Re: crx help
as far as the swaping engines im fine with that its the electrical stuff im not so sure of.you said i may have to swap some pins in the plug.how will i know witch ones to swap and how do you swap them?
02-26-2008, 08:15 PM
Re: crx help
oh and one more thig is there a way to tell if a head is cracked or if its a gasgett without takeing it to a head shop?
02-26-2008, 11:23 PM
Kind of a Big Deal
Re: crx help
only way to tell is a compression or leak down test, if everything specs out, its fine... if it doesnt, theres something wrong
02-27-2008, 01:50 AM
Re: crx help
hey,will a distibutor from my 91 d15b6 work in my new d16a6 from the 88,the 88 d16a6 is missing and i dont know witch one i need to replace it with.
