1987 S-10 4X4 Auto. 2.8L V6, Timing? Power?
Google
Web AF
mcc88
02-25-2008, 05:32 PM
I have a 1987 S-10 with the small 2.8L V6. It's an automatic with 4 wheel drive. I was wondering if anyone knows what the stock timing should be set at. My truck is getting worse milage and lack of performance. I has variable miss here and there. It has fairly new plugs and wires in it. I just wonder if the timing has been messed with in the past, cause it should get better milage than what it does? Should have more power too? Thanks!
MT-2500
02-25-2008, 05:47 PM
Carb ot tbi or std or auto.
Most are +10 degrees base timed.
But with the tan and black stripe bypass wire disconnected.
It is under heater core housing in the cab.
MT
mcc88
02-25-2008, 06:11 PM
MT
My truck is TBI, and auto trans. ?
MT-2500
02-25-2008, 06:33 PM
Base times +10 dergres with spout connector disconnected on it.
MT
mcc88
02-25-2008, 07:06 PM
MT
Is the "spout connector" the "tan and black bypass wire" you was mentioning earlier? thanks
MT-2500
02-25-2008, 07:16 PM
Yes
mcc88
02-25-2008, 08:11 PM
Yes
Thanks, I'll give it a try.
Google
Web AF
