92 four runner
cam366
02-24-2008, 01:19 PM
when should aperson change the timing belt on 3.0 v-6 engine?thanks david
Brian R.
02-24-2008, 01:58 PM
Gates (timing belt manufacturer) recommends every 60,000 miles under severe use conditions.
cam366
03-04-2008, 11:08 AM
also brian,how would oil and dirt get in the bell housing,clutch area other than the clutch arm boot hole?Clutch slips some and I think it may be the oil etc.What if i drill a hole about 3/8จจ and drench with carb spray first and then brake kleen to clean it some and wuill drain out the hole?give me some ideas to cut corners.thanks dave
Brian R.
03-04-2008, 11:45 AM
It is a bad idea to spray anything on the clutch plate. It will absorb anything you spray on it, and you really can't get to the clutch unless you disassemble it since it is pressed for its entire area between the pressure plate and the flywheel.
If the clutch is slipping, it is either out of adjustment (not possible in your case), or the pressure plate has been overheated and the springs have lost their tension, or there is no longer enough clutch lining to keep it locked up, or it is contaminated. Replace the clutch and/or pressure plate.
cam366
03-04-2008, 12:00 PM
brian,where is the adjustment?I thought it should be between the slave and arm,but not really anything there.You are right the clutch is probably contaminated atleast.I plan to replace it next week and was asking some questions and alternatives if any.While I do that what else might be done beings it will be that much apart?besides throw-out and pressure plate. seals ?thanks alot brian,appreciate answers
Brian R.
03-04-2008, 01:39 PM
The only adjustment available to you is pedal free-play (adjusted to 1-5 mm behind pedal at push rod). This may be your problem, as well as possibly a binding release fork. You can grease the release fork with moly grease at all the contact points. You can also adjust pedal height, but it can't cause a slipping clutch.
You can check the pilot bearing once you have the clutch removed. If it is rough or turns with difficulty, replace it.
