98 4Runner wont start when warm.fabvolcano 02-22-2008, 06:18 PM After driving my 98 4runner awhile, if I stop and turn it off for 10 minutes or so it won't start. Seems as no fuel if getting to it. It attempts to start, if I press the excelerator it stops trying. A little squirt of starting fluid in the air intake will start it. If it sits for an hour or so it will start on its own. Only happens when its warm. Thanks for any help. Brian R. 02-22-2008, 09:11 PM Try running a can of injector cleaner through the gas tank. Check your air filter element Check the ECT sensor Check the injectors for leakage. See if you have fuel pressure when it won't start. See if injectors are clicking when you are cranking the engine and it won't start. Automotive Network, Inc., Copyright ©2012
