5efe vacuum line routing?atinylittle 02-20-2008, 10:31 PM I swapped my engine in my '92 Paseo for a much less used engine. I forgot to make a note of how the vacuum lines on the VSV (Vacuum Solenoid Valve) are supposed to be routed!! OOPS!!! It controls the fuel pressure and I think I hooked them up wrong!:confused: My little 4cylinder now guzzles gas. I have a Toyota Paseo Shop Manual, but it only shows the vacuum line routing for the California Automatic VSV assembly. I have a manual transmission, and my VSV only has 3 vacuum lines going to it. Please Help! Brian R. 03-03-2008, 12:30 AM You should either have a vacuum routing diagram on the underside of your hood, or be able to order one with your VIN from a Toyota parts counter. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
