question for 1995 mazda 626toycam 02-20-2008, 10:01 PM i have a 1995 mazda 626 and the engine light came on i am trying to pull codes and cant find anywere how to.what i have read said ground/#10 bridge to make flash #10 is a empty slot.then i read ground/fen bridge them to.but the fen slot is a emty slot to.so if anyone can give me the correct procedure i would apreciate .it is a 1995 mazda 626 automatic with the 4 cylinder 16valve engine.thanks the problem it doing since light came on is pops or dies if you accelerate to fast seems fine if you accelerate slow chubzzam 02-22-2008, 12:02 AM check put ur fuel pressure.. toycam 02-22-2008, 12:38 AM i am trying to pull codes to see why the engine light is on.thanks chubzzam 02-29-2008, 11:04 PM i am trying to pull codes to see why the engine light is on.thanks go here for better understanding/procedure to pull codes http://www.mazda626.net=2 (http://www.mazda626.net/index.php?showforum=2) Redblue22 04-16-2008, 05:40 PM i have the same car same year and everything and my engine light came on we called a place that would do it for free it was my O2 sensor my car would idle really crappy close to death once i replaced the O2 sensor it was fine. so i would find somewhere to pull the codes its OBD1 so its hard to find a place that does it seeing as most pull only OBD2 these days. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
