Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 02-18-2008, 06:22 PM   #1
dennis_chubs
dennis_chubs Normal reputation
Exclamation no start
have a 92 grand prix have changed crank sensor still only turning over possibly a igniotion modddd orr ignition sswitch
dennis_chubs is offline   Reply With Quote
Old 02-19-2008, 07:02 AM   #2
GTP Dad
Pontiac Guy
GTP Dad Normal reputation
Re: no start
Welcome to AF!!
The first thing to do is to see if you have the basics. Fuel and spark without either one the engine will not start. If you have no fuel check the fuel system ie fuel pump, fuel pump relay, fuel pressure regulator and injectors. This also includes the ECM. If you have fuel then spark is next. I suspect the ignition module may be bad and not producing a spark. This could also be a coil issue.
GTP Dad is offline   Reply With Quote
Old 02-19-2008, 11:13 AM   #3
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: no start
Another common issue on your year Grand Prix is a failed ECM. The OEM part#1227727 is known for premature failure, mostly due to being mounted under the hood and exposed to the elements. They can and will work intermittently before failing completely.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Bookmarks
Google
Web AF
