Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > El Camino
Old 02-16-2008, 05:09 PM   #1
chrysler_300
chrysler_300 Normal reputation
86, elco, q-jet 4bbl,, idle problems
1986 el camino
new reman carb, idle fluxuates btwn 600-900rpm, cked vacuum, pugs, work fine with old carb, choke broken and sensors
chrysler_300 is offline   Reply With Quote
Old 02-22-2008, 09:22 PM   #2
M Nelson
M Nelson Normal reputation
Re: 86, elco, q-jet 4bbl,, idle problems
It's not uncommon for a "rebuilt" carb to malfunction immediately after being bolted down, and Q-jets are the most common to get a bad re-build. There are these little "soft plugs" in the bottom of the bowl on Q-jets that tend to leak,and drizzle raw gas directly into the intake manifold. Some rebuliders put a little spongy thing under them to soak up the gas, but that is not a permanent solution. Take the top and bottom off of the carb and put it on a clean 2x4 or something similar. Fill the bowl with gas and see if it leaks. By using a piece of wood , you can let it sit overnight and check if the bowl goes dry,and also if the board is wet or stained.
I wouldn't buy a rebuilt. Get a new one. The lower price is more attractive, but sometimes you really do get what you pay for.
M Nelson is offline   Reply With Quote
Bookmarks
Google
Web AF
