Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 02-16-2008, 01:17 PM   #1
chadnyne
chadnyne Normal reputation
89 K1500 starting problem
I have a 1989 K1500 with the 350 V8. My mechanic just replaced the intake manifold gasket as it was leaking oil. I started it today and it started fine. I drove it about 10 miles and stopped for gas, and it barely restarted, like the battery was suddenly weak. Fearing it would not restart, when I was loading an item at the store, I left it running. When I put it into gear it stalled and I had to restart it. It was slow to start again. It ran fine on the way home, held idle at stop lights ok. I put it into reverse to back into the drive and it almost stalled. I gave it gas to keep it running. I plan to replace the battery, but I know my luck and it probably won't be that easy. What else should I check that the mechanic might have messed up during the manifold gasket change? The neg cable appeared secure to the manifold. I'm not sure what else to look for, and if I take it back to the shop and the problem doesn't immediately appear, I'm sure they will send me packing without doing anything. The fuel pump was replaced on the vehicle about a year ago. No other work has been done.
chadnyne is offline   Reply With Quote
Old 02-16-2008, 01:45 PM   #2
Headnsouth
Headnsouth's Avatar
Headnsouth Normal reputation
Re: 89 K1500 starting problem
How old is the battery? Get the battery load tested at a auto parts store they'll do it for free.
AS far the stalling goes I'd look for a vaccum leak on the manifold. Spray some carb cleaner along the gasket while its running being careful along the exhaust manifold. Carb cleaner is flammable.
Headnsouth is offline   Reply With Quote
Old 02-16-2008, 09:48 PM   #3
chadnyne
The battery is older. The odd part is that if you leave it sit for a while, the engine turns fine. If you try to start it while it is warm, it turns very slow like a bad battery. It is almost like something is draining it down while it runs...I will check the manifold.
Old 02-16-2008, 10:22 PM   #4
RPerformance
RPerformance Normal reputation
simple thougt but is the alternator hooked up? unless you are running the lights it will run along time without the alternator. simple check is to start up and pull the positive cable from the battery. if it keeps running the alt is working.
RPerformance is offline   Reply With Quote
Old 02-17-2008, 04:05 AM   #5
G.A.S.
G.A.S. Normal reputation
timing could be an issue as the distributor was out for the gasket change.
wouldnt hurt to take it back and show them what it is doing.
the symtoms you talk about lead me in that direction
G.A.S. is offline   Reply With Quote
Old 02-17-2008, 12:09 PM   #6
chadnyne
Tried the disconnecting the positive cable test. The truck stayed running. I then turned on the headlights with the cable still disconnected and it immediately stalled out. What does this tell me? I tried the same test on another vehicle and it didnt stall with the with the cable off and lights turned on. In any event, the wires at the alternator are attached and secure. I haven't tried the carb cleaner test yet as it is 31 degrees and raining here, not pleasant work conditions...
Old 02-17-2008, 07:56 PM   #7
777stickman
777stickman's Avatar
777stickman Normal reputation
As mentioned, do a load test on the battery. If that checks good replace the battery ground cable.
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
777stickman is offline   Reply With Quote
Old 02-18-2008, 12:14 PM   #8
RPerformance
sounds like the voltage regulator in the alternator is not putting out enough juice
Old 02-24-2008, 10:03 PM   #9
chadnyne
I replaced the negative cable. No improvement. Still motor turns fine when cold, but turns slow to restart when warmed up. Since it turns fine when cold, I'm guessing the battery is fine. Should I pull the alternator and have it tested? Idle issue is sporadic. It sounds fine cold, but the idle surges sometimes when warmed up. Today I ran it and the idle seemed fine. The day before it was surging up and down. I need to get some carb cleaner to test the manifold gasket.
Bookmarks
Google
Web AF
