Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 02-16-2008, 10:58 AM   #1
kukukbird
kukukbird Normal reputation
Speedometer calibration on 95 Tacoma
I have a 95 2wd tacoma (2.4L , automatic) that still has the factory 14" wheels on it. I want to put bigger wheels but I do not want the speedometer to be off. Can anyone tell me how I would calibrate the speedometer if I went to 15" wheels and taller tires?
kukukbird is offline   Reply With Quote
Old 02-17-2008, 06:25 AM   #2
Flash75
AF - Advisor
Flash75 Normal reputation
Re: Speedometer calibration on 95 Tacoma
Your speedometer is probably electronic with no speedometer drive cable. Check with a 4 wheel drive repair shop for suggestions on where to get your speedometer calibrated. If it's electronic it's not as simple as turning a screw or changing a gear. If it's a mechanical speedometer, you can have a speedometer shop build a ration adapter.
Clifton
Flash75 is offline   Reply With Quote
Old 02-17-2008, 11:28 AM   #3
kukukbird
It looks like I have a mechanical speedometer. I looked at my transmission and saw that I have a cable going into the side of it.
Can the plastic gear be changed that the cable goes into or does the gear on the tailshaft need changed also.
Old 02-20-2008, 05:16 AM   #4
Flash75
AF - Advisor
I'm not sure if different plastic gears are available. Some older American cars did have several different plastic gears, but they had a housing you could rotate to correct the gear seating when a different diameter gear is used. Ask your dealer if Toyota has different plastic gears.
Clifton
Bookmarks
Google
Web AF
