Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 02-14-2008, 02:05 PM   #1
Linksmaker
Linksmaker Normal reputation
Is there a trick to Quick disconnect Fuel Lines on 99 Blazer?
I'm replacing the Fuel Pump and can't get the center and driver side fuel line off the Fuel Pump. The driver side looks like a quick disconnect with the pinch style disconnect but the center looks different. Anyone have tips for getting these off?
Linksmaker is offline   Reply With Quote
Old 02-14-2008, 04:03 PM   #2
brcidd
brcidd's Avatar
brcidd Normal reputation
Re: Is there a trick to Quick disconnect Fuel Lines on 99 Blazer?
Yes- run Forest run- down to the nearest parts house and get the fuel line disconnect tool- makes the job a snap-...
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 02-15-2008, 07:20 AM   #3
mike2004tct
mike2004tct's Avatar
mike2004tct Normal reputation
A little tricky to get out; push the line into the receiver end, while maintaining pressure on the line, pinch the two levers of the quik-connect down, then pull the line out.
As for the vent (center line), you can twist that one over it's receptacle end.
It's malleable enough to take some bending, and will just snap back over the tube when you replace it.
When you replace the fuel lines, be sure to get new pinch fittings (Napa sells them separately, 3/8" for the return, 5/16" for the feed line).
Napa also makes the quick release dies mentioned above, if you can't remove them manually. It's about $12.00 for a set of 8 plastic dies (They look like large split coins)
Good luck.
It's my opinion, don't take it personal.
'04 T&C, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
mike2004tct is offline   Reply With Quote
Old 02-16-2008, 07:32 AM   #4
robertintx
robertintx Normal reputation
Yea, the first answer you got is correct. Go to the parts store and get a quick disconnect tool. There under 4.00 dollars. but sometimes it's still difficult to get the tool in place because of support around the fuel pump tube. But it will work eventually.
robertintx is offline   Reply With Quote
Bookmarks
Google
Web AF
