Wheel Stud Replacement
Bunky1267
02-13-2008, 10:59 AM
i took my van and had the tires changed and the guys must of cross threaded the nut on one of my wheel studs, I ended up snapping it off, now I need to replace it... do I have to take the hub out or is there enough room to get a new stud in with out ???/
rockwood84
03-07-2008, 03:15 PM
the studs knock out of the hub with a punch .a good parts guy can get you the correct one by the year ,make and model. get the stud and nut. usually when i put it back in i get a bigger nut and pull it in a little then after i get everything back together take the tire tool and pull it the rest of the way as i tighten the lug nuts up with the tire on.an impact is tough on lug nuts.
darnsuprat
03-19-2008, 12:04 PM
The studs and the hole it goes into have splines, so be careful not to spin the stud when you install it otherwise it won't "lock".
I don't think you have to remove the hub. There should be enough room just to pass stud it in from the back. I've done this on my 97 Voyager a few years ago. Not sure about the venture.
Good luck.
Darren.
