I know this isn't Lumina But...
Bearwulf
02-13-2008, 02:06 AM
No one seems to check Chevette anymore. I need to know how to adjust caster/camber on '78 Chevette, have manual coming but it was ordered online and might take 10 days to get here.
My wife just bought this one, right side needs adj't badly. First one of these that I have worked on.
ANY HELP greatly appreciated.
THANKS.
jeffcoslacker
02-13-2008, 08:44 AM
Most are so rotted by now you should be able to open the hood and grab the shock towers and spread them apart...be careful not to rip it in two :rofl:
J/K...I'll see if I can see something...IIRC they had a pretty conventional style front end? Don't you just add/subtract shims to the upper arms?
Most of those when they had a wheel leaning, the lower ball joint was about to break...I think you checked for the boss around the grease zirk receeding into the ball joint's flat face...if it is flush or receeded, it's shot...check unloaded (lifted under body, not by control arm)
Used to see lots of those with broken joints on the side of the road...people didn't check them right...
j cAT
02-13-2008, 11:58 AM
THANKS.
did you or your wife decide to go with this death trap? don't waste your time money life........
jeffcoslacker
02-13-2008, 12:16 PM
They're fun if you get a real basic one...I had a friend who had a basic w/3spd manual and no power accessories, we lowered the coils (torch job) and put poly bushings in it...it was like driving a real big go cart...fun!
Then another friend had one in high school that had power everything, A/T, PB, PS, A/C, etc...put four people in it and it was lucky if you could hit the speed limit with a 2 mile run...
jeffcoslacker
02-13-2008, 12:23 PM
Sorry it's been too long...check those LOADED, vehicle on the ground. Boss around zirk should stand up slightly above the bottom of the housing. If flush or receeded, it's shot...
16th hippy
02-14-2008, 07:54 AM
saw a wheelie stand competition on speed on demand the other day. only guy to flip over onto the roof was a shove-it....i mean chevette. gremlin came close, but not close enough. my mom had one when i was a youngin, and was kinda crappy, but for $300, it lasted awhile.
Bearwulf
02-15-2008, 11:11 PM
Thanks I will get right on that.
BTW it was the wifes idea. Never cared much for those glorified tuna cans myself.
j cAT
02-15-2008, 11:44 PM
back in 82 my friend had one it was always in need of repairs could not handle the pot holes very fragile vehicle....
Bearwulf
02-20-2008, 03:12 AM
Manual finally got here. The only camber adj. is to unbolt & rotate the top ball joint 180 deg. which will only change it about 1 deg.
jeffcoslacker
02-20-2008, 09:48 AM
Interesting...did not remember that about them...
