1994 saturn has starting problem only in cold?
tjr19136
02-11-2008, 07:25 PM
When ever it's below freezing out-side my car will start-up but once i cut it off and try to cut it back on........I got to put my foot on the gas while cranking it............. I happend twice and only in below freezing temp.
RC1488
02-12-2008, 12:46 PM
Sometimes you need to help the car get going when its really cold out. Oil viscosities are high and add resistance to the engine. Its not a huge problem if all you need to do is give it a little gas to get the car started. If this happens everyday and giving it gas does nothing, then your Crankshaft Posistion Sensor may be at fualt. A checking of spark between the towers on the coil pack when the car does not start will indicate if the CPS is bad and needs to be replaced.
Im not sure about you, but i know i dont let to get started when im freezing :)
