Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 02-09-2008, 12:06 AM   #1
pushing300m
pushing300m Normal reputation
92 blend door -WHERE is it????
Location of the blend door actuator??!! Newby to site. Checked all 5163 posts looking for something specific. I have a Chilton manual and a sheet from the Ford dealer that sold the actuator to me. Neither matches what I see under the dash!! Feeling kinda silly. Both hoses to core hot; not plugged. Cold air only. No antifreeze vapor.
pushing300m is offline   Reply With Quote
Old 02-09-2008, 05:20 AM   #2
tripletdaddy
tripletdaddy Normal reputation
Re: 92 blend door -WHERE is it????
My haynes shows it on top of the heater case assembly on the left most rectangular box, housing the heater core. This is to the left of a verticle box that splits in the middle and has a rounded bottom, housing the ac evaporator core. The fan should be mounted to the farthest right in a round box. The actuator has a bundle of wires leaving from the front of it and two wires crossing the top of it to the back of the air housing.. "To remove actuator, disengage it from bracket, lift upwards 1/2" , then move towards you."
Hope this helps
tripletdaddy is offline   Reply With Quote
Old 02-09-2008, 02:57 PM   #3
way2old
TOKEN HILLBILLY
way2old's Avatar
way2old Normal reputation
Here are the directions from AlldataPro.
Disconnect the battery ground cable.
Loosen the instrument panel and pull it back from the cowl.
Remove the blend door actuator electrical connector from the bracket on the evaporator case.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Bookmarks
Google
Web AF
