Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Explorer/Explorer Sport Trac
Old 02-08-2008, 09:10 PM   #1
TeamExploder
TeamExploder Normal reputation
Send a message via AIM to TeamExploder
Child Locks!
I didn't have this prob. with my 96 since they were turned off but my 95 XLT it seems as if the child-proof locks won't turn off, its irritating having to open the back door for people and I've only done it a couple times. If anyone thats had an explorer with these before can help me, let me know, I'd appreciate it alot I usually try to help here but now I'm stumped.
Oh and if there is anyway of turning off this auto-lock ya know you press the brake and release and the doors lock themselves, if there is a way of turning this off let me know about that too.
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1998 Escort ZX2 2.0L DOHC 5spd
1999 Malibu. 2.4L DOHC Auto
TeamExploder is offline   Reply With Quote
Old 02-08-2008, 10:35 PM   #2
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Re: Child Locks!
The child locks may not be the problem, but instead the problem may be the release lever for the inside door release. Try pulling firmly on the interior door handle to see if that allows the door to open. I assume you've trying cycling the child locks and/or looked over the owner's manual first.
I remember seeing others post of similar problems. I believe the concensus has been plastic has stretched and is no longer fully actuating the linkages.
-Rod
shorod is offline   Reply With Quote
Old 02-09-2008, 08:34 AM   #3
TeamExploder
Re: Child Locks!
Alright thanks Rod, I don't have the owners manual for the one but guess I can look in the other, on the door it has a sticker that plainly states which way to flick the lock but I've tried and nothing, so guess I'll see if yanking a little hard on the inside door panels will fix the prob.
Old 02-09-2008, 02:51 PM   #4
way2old
TOKEN HILLBILLY
way2old's Avatar
way2old Normal reputation
Re: Child Locks!
go to www.fleet.ford.com and click on maintenance tab, then click on owners maunal, enter info and click submit. Will give free owners manual. Whew, think I need to stick that site.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 02-09-2008, 02:53 PM   #5
way2old
TOKEN HILLBILLY
way2old's Avatar
Re: Child Locks!
Go to www.fleet.ford.com and click on maintenance tab, then click on owners manual, enter information and then click submit. Presto---free owners manual. WHEW, think I need to make that site a sticky if anyone would use it there.
Old 02-15-2008, 12:37 AM   #6
Jacfourteen
Jacfourteen Normal reputation
Re: Child Locks!
I have a 99 explorer, I used to have a 91, and my sister has a 92 and they have all had the same problem. What happens is there is a set of plastic gear-like teeth inside the handle mechanism and one of the teeth break off causing the handle to not work. To fix mine I just found one in the junk yard. Any handle from 91-01 should work assuming it's the same side (front and rear are the same). As an example when my 99 broke it was the front pass. side, I used a pass. rear from a 93 and it was the exact same part. Also don't try to use a ranger handle, some look similar but they don't work (tried it!). Hope this helps!
Jacfourteen is offline   Reply With Quote
Old 02-15-2008, 05:59 AM   #7
TeamExploder
Re: Child Locks!
Yeah, thanks for the heads up, my driverside also dont work but been too cold or rainy or snowy or really windy and haven't been able to take it apart to see what the driver door issue is.
Bookmarks
Google
Web AF
