some nuisance(s)... some help!?!
xivera
02-23-2003, 01:17 PM
I have a few minor problems w/ my ride.
In order of priority, they are:
- During winter, my turn signal switch/lever-thingie likes to get stuck every time I switch it over to hang a right/left turn. (ie. Once I switch it to make a left turn, it's stuck in that position until I put it back.)
- Also during winter, my Pioneer CDX-PD6 (my pride & joy of my system... the in-dash 6 cd changer :D) goes on the fritz when I choose to change a disc. (ie. Once I change a disc, the unit spits it back out and sends out 'Error-23' signals.) To alleviate this pain, I just warm up the car real toasty-like prior to any cd swaps.
I get really pissed over this... because I end up driving longer than should, which is fine... Who doesn't like cruising for a bit!?
- Lastly, my left-most light in the HVAC control isn't fully lit until I "pitik" (Tagalog for "flicking one's finger to lightly strike an object"... except I can do it real hard... like my Dad) it.
I can't believe that I'm actually going to address these after so long...
93speed
02-23-2003, 08:17 PM
A suggestion for the CD Player part:
Check your CD's for "fog". On really cold days, my CD's fog up and the player won't read them correctly. To fix it, I just wipe off CD on my seat or put it in front of the defroster.
sparq
02-24-2003, 05:00 AM
Yup, for the CD's keep them inside, but it sounds like the lens is "fogging" or frosting up - sounds like all the problems you mentioned have to do with the vehicle being cold. Get a remote start and let the bitch warm up before you take it out :smoka:
shepworldwide
02-24-2003, 06:22 AM
try installing a new switch..if that does'nt work then rip apart your steering assembley and clean around the lever n such
i don't even have a system in my ride,but if i did it would involve zero pioneer components!! get used to it
take apart your dash and fix the loose connection for your light?
in conclusion why would you have getting a helms manual for your first mod and ask these types of questions :confused:
getting a manual was going to be my first response till i noticed you had it... i hope these awensers slove you problems :bandit:
jer28usa
02-25-2003, 11:23 AM
I recently the same problem as you did with the heater control lights. Do a search on heater control and it should come up. I wrote up a procedure that I used when I fixed this on my car. I am much happier now that I don't have to hit my dashboard anymore!
