Strange Transmission problem -98 3.0
ml_mn
02-03-2008, 11:08 AM
I have problem with that when i switch from park to drive it feel like the trans swith to drive but when i hit the trottle the enginge just revs the same is for revers and 1st but if i put in 2 it will work and if i switch to D after that the car start moving the trans work normal until i stop nex time.
The other thing i can do s to rev the enginge up to aprox 3-4000 rpm in Park, Rev, D ,2 or 1 and it start working again.
i have more problem when the trans is coold.
wiswind
02-03-2008, 05:19 PM
The Transmission Range Sensor, aka Neutral Safety switch, is a common source of problem.
It is also about the cheapest and easiest thing to address.
Beyond that and possibly a fluid and filter change, it would be best to have a good transmission technician check it out.
ml_mn
02-04-2008, 01:40 AM
I have allready done fluid and filter change X 2
and will dubbel check the TRS
