changing a front driving light bulb
lou S.
02-02-2008, 09:55 AM
I have a 2003 that has a front light bulb out(one that goes on when you hit the remote) in the directional light assembly. Is there some "trick" to changing that bulb/removing the lens cover? Thanks for any assistance you can provide.
J-Ri
02-04-2008, 05:28 PM
There should be two "L" shaped rods. The short part is on the top of the assembly and clips into some plastic "c" clips. Just unclip them, pull up (may need to rotate while pulling), and the assembly slides right out.
lou S.
02-05-2008, 07:56 AM
Thanks. I'll give it a try.
lou S.
04-08-2008, 08:39 PM
Finally got around to changing it after most of the snow melted. Thanks, tip worked great----took the headlight out and was easily changed out.
