Gauges in and out
jffwht
01-30-2008, 02:30 PM
I have a 98 that when you start it the gauges all come on fine then when shifting to drive the temp., speedometer and fuel gauges drop. I can put the truck in neutral turn it off and back on and the gauges work fine. I also found out that when the gauges are down the wipers don't work either. Any help on this?
jffwht
02-05-2008, 03:30 PM
I have discovered the problem with the wipers. Basically the board behind the motor was fried and the connections were as intermittent as the wipers needed to be.
G.A.S.
02-05-2008, 04:11 PM
did that correct the guage problem?
jffwht
02-11-2008, 02:16 PM
The guages still go in and out. Is it possible to have a wire loose or ungrounded under the brake pedal. It appears to pop back on when I stop and have applied the brakes.
