98 sho head removal03impala9c1 01-29-2008, 10:48 PM well i suppose i should start a new post now on this issue. 3.4 dohc v8 to remove the front head am i going to have to remove the engine? I know to replace the timing chain you do... but can i work around this to get the front (left) head off? shorod 01-30-2008, 02:08 PM There are a couple of places that have made quite a business out of welding the cams in the car. They probably know what it takes to get the heads off. You may want to check with those places, as well as review articles on the V8SHO.com site that I suggested in your previous post. -Rod 03impala9c1 01-30-2008, 06:02 PM yeah but heres the thing i did a cylinder leakage test on the front head and found all 8 intake valves are bent 95% leakage in every cylinder... so time for a different head, which would be cheaper than fixing this one. I can't find just the cam except at one dealership for 458.00 and valves are 10 bucks a piece... so... i can find a head for 300 complete. mwt47 01-30-2008, 09:59 PM yeah but heres the thing i did a cylinder leakage test on the front head and found all 8 intake valves are bent 95% leakage in every cylinder... so time for a different head, which would be cheaper than fixing this one. I can't find just the cam except at one dealership for 458.00 and valves are 10 bucks a piece... so... i can find a head for 300 complete. You can find a cam failed motor and use the good head off of it. You have major problems and the V8 is not an easy motor to work on. You could very easily have pistons with holes in them too. www.shoforum.com (http://www.shoforum.com) may be a better bet than v8sho.com Mike :smokin: shorod 01-30-2008, 10:29 PM www.shoforum.com (http://www.shoforum.com) may be a better bet than v8sho.com Mike :smokin: Agreed, I forgot about that one. -Rod 03impala9c1 02-02-2008, 09:18 PM thanks for the help in gonna be replacing the whole motor for less than a grand and ill have cams welded while its out! Automotive Network, Inc., Copyright ©2012
