Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Ranger/Courier
Old 01-29-2008, 10:35 PM   #1
backerm1
backerm1's Avatar
backerm1 Normal reputation
valve stem seals
is there a special tool to do the valve stem seals??? where do you buy it?
backerm1 is offline   Reply With Quote
Old 01-29-2008, 11:13 PM   #2
toddler62
toddler62 Normal reputation
Re: valve stem seals
I'm assuming your wanting to pull new valve stems through the hole in the wheels. Yes there is a tool that screws on the threaded end of the valve stem after you put it in through the hole. They should have this tool at any auto parts store
toddler62 is offline   Reply With Quote
Old 01-30-2008, 07:43 AM   #3
backerm1
backerm1's Avatar
no i need to compress the springs under the valve cover. but they are covered and my spring compresser won't fit.
Old 02-07-2008, 07:03 PM   #4
DonSor
DonSor Normal reputation
Do you have the head out? It's pretty tricky replacing valve seals in place? for one you have to have the rocker arm lossened or removed so you can compress the spring. Careful when you remove the snap ring as the valve may slide down the cylinder.
DonSor is offline   Reply With Quote
Old 02-09-2008, 07:07 PM   #5
backerm1
backerm1's Avatar
nope the the head was out, it is a wierd shaped head, with four big bearring stacks and metal houses for the springs, it doesn't even have rockers. the manual says ford made a special tool for it. but hell I still can't find it.
Old 02-09-2008, 10:06 PM   #6
DonSor
Sorry I missed it but what manufacturer/model/year car is this?
Old 02-10-2008, 08:49 AM   #7
backerm1
backerm1's Avatar
88 Ranger
Old 02-10-2008, 10:55 AM   #8
DonSor
4 or 6 bangers? Either of this type engines have overhead cam. I've worked on both types and I don't recall anything but the standard 4 in line or V6 configuration. Sure would like to see it as you described.
Old 02-10-2008, 11:12 AM   #9
backerm1
backerm1's Avatar
its a 4 cyl. 2.3L EFI, OHC not turbo. 4 plug head. how did you get the springs out? how do i upload a pic?
Old 02-10-2008, 11:19 AM   #10
DonSor
Using a spring compressor but if you don't have the necessary tools, simply take the head to a parts jobber (auto shop) and let them check it out.
Old 02-10-2008, 11:42 AM   #11
backerm1
backerm1's Avatar
Ok, I found the tool at ford, the jobber shop priced it $250, i just stuck it back on. probably professionally rebuild the whole dang thing when I get the money. What brand of compressor you have? is it on the car or off the car?
Old 02-10-2008, 01:42 PM   #12
DonSor
You can get a valve job complete with new seals and your head resurfaced if necessary and the chamber decarbed for less than $250. Stay out of the dealers cause they'll soak you. There are lots of auto machine shops that do good and inexpensive work. I've used them before. Be aware however that with the valves tight your rings have to be in good shape otherwise you'll have blowby problems.
Old 02-10-2008, 02:06 PM   #13
backerm1
backerm1's Avatar
$250 did sound like alot to me too. I've had 5.0 strip heads built for less than that. I'm in a new town, so I'll look around some. What compressor do you use, I'd rather not buy an expensive ford tool, that I will only use once
Old 02-14-2008, 04:27 PM   #14
DonSor
I work part time for Pep Boys and we have loaner kits which you buy and when you return it within two weeks, you get your money back. I'm pressure we have the spring compressor kit. AutoZone I believe has the same service.
Old 02-14-2008, 06:00 PM   #15
backerm1
backerm1's Avatar
yeah part stores like that are awesome, unfortunately the closest store like that to me is over 4 mi. away.
Bookmarks
Google
Web AF
