Need help programing the keyless entry number pad located on the driver door.DanielleMcCurley 01-29-2008, 10:17 AM I bought a 2001 Ford Windstar Sport SE and it has one of those number pads on the outside of the door so you can punch in your code and unlock your car. Well, I don't know the code, but is there a way to reprogram it myself? I looked through the manual and saw stuff about reprograming the keyless entry key ring but nothing on the keypad at all. Thanks tomj76 01-29-2008, 11:43 AM grog11 01-29-2008, 05:25 PM Try looking under the drivers side dash, there should be a black box there with the numbers on the side that tell the code. If I remember right the box is positioned on the inside firewall up higher than the fusebox level. You may want a flashlight and a mirror handy. garync1 01-29-2008, 10:26 PM Try looking under the drivers side dash, there should be a black box there with the numbers on the side that tell the code. If I remember right the box is positioned on the inside firewall up higher than the fusebox level. You may want a flashlight and a mirror handy. I did that on my freestar and it was the last 5 numbers.. on the box..But it was a freestar.. DanielleMcCurley 01-30-2008, 12:58 AM Will it say "Keyless Entry Code" or will it just look like a serial number type thing that is on the box? I looked up behind my gas and brake pedals and up under the dash and found a few box type things with a serial number sticker thing on them, but I didn't have a flashlight and wasn't able to read the numbers. Automotive Network, Inc., Copyright ©2012
