New Carxplodn 01-29-2008, 09:11 AM I just got a 02 3.5SE and have a few questions. The drivers headlight is aimed too low, does anyone know how to adjust these?? Also does anyone have a dash mat? How does it look? I'm sure ill be around in this forum a lot. See you all around. shab_xp 01-29-2008, 11:32 AM Yes, you can adjust the headlight. For most cars, it can be adjusted both vertically and horizontally. What you need will be a screw driver. Do it at night, park you car in a level place with the headlight facing a wall. I think you can find this information from your manual. I just got a 02 3.5SE and have a few questions. The drivers headlight is aimed too low, does anyone know how to adjust these?? Also does anyone have a dash mat? How does it look? I'm sure ill be around in this forum a lot. See you all around. xplodn 01-29-2008, 11:38 AM Yes, you can adjust the headlight. For most cars, it can be adjusted both vertically and horizontally. What you need will be a screw driver. Do it at night, park you car in a level place with the headlight facing a wall. I think you can find this information from your manual. There are no obvious adjustments, all the manual says is see your dealer, aka be ripped off JoeShmoe 01-30-2008, 11:29 AM you should be able to find little gear looking adjusters. They might be hidden from view so might have to remove some cover panels to get to them. Make sure you give it a couple of bounces before you do it. Let us know either way. xplodn 02-06-2008, 09:17 AM I got the headlight adjusted, I was at the dealer lookign for a dashmat (which is not to be found to match my interior), and a service guy showed it to me, you have to remove air cleaner on one side and a bunch of crap on the other, very hidden. Automotive Network, Inc., Copyright ©2012
