Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-26-2008, 05:36 PM   #1
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
87 heater intermittent no heat
This is in response to a thread I saw a while back concerning loss of heat from the heater. Unfortunately, I can't find the thread so here I am.
In the posts we had narrowed it down to a faulty temperature slide switch on the control panel. It normally slides laterally but I noticed if I forced it either up or down, the heat would return. I also noticed as I did that, a door actuator at bottom forward behind the center console would actuate allowing heat to enter the cabin. I finally got around to fixing it and it was fairly easy.
I removed the control panel and took it apart to inspect the circuit board. There are actually two, the main board and a smaller board the two connectors connect to. On the smaller board I found eight bad solder joints. All were cracked and seperating probably from torque stress from the connectors. I re-soldered them and the solder points for the switch itself, reassembled the panel and all is now well. Also fixed flickering panel lights in the process. If you have an 87 or therabout and need to try this I will gladly pass on the details.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is offline   Reply With Quote
Bookmarks
Google
Web AF
