Originally Posted by trackertrouble
coolant level is ok ...... as for the possibility of blown head gasket, as suggested by marc-o-matic, wouldn't that cause some overheating? it's actually running cold??? I'm sooooo confused. Anyway, thank you both for your ideas!!!
trackertrouble
Yes and no if the coolant is low or there is an air pocket the guage can't read properly.(it's a coolant temp. sensor not air temp. sensor)
The reason I mentioned that is the combination of a missfire and milky oil.
Oil turns milky when mixed wilt water/coolant.
You might want to remove and inscect spark plugs,start w/#3
(any sign of water/coolant).
Also the smoke,what color is it,or is it steam/vapor?
