Re: 94 1.9 escort roller lifter oil hole
it should be on the opposite side so the oil has to flow around the oil grove in the lifter making a seal & alowing the lifter to stay pumped up. if you line up the hole with the head the oil will run back into the head & the lifter will fail. I had this problem on one lifter & compaired it to 3anothers in the head. The Haynes manual even tells you the wrong way!
