Re: Door Jam Problems Need help!
depending where you are, it could be frozen, mines been doing this in below 20 degree weather. been awhile since i had the panel off, if i remember right it does just pull off, you need to replace the clips they break when you pull it off so go to an auto store and pick some up before you tear it off. just check it out and see if you can find any screws. You need to remove the window crank if you have manual windows that is a special tool, the auto shop should have that too.
1980 El camino
2002 LS1 swap
