Serpentine beltcmonte1995 01-22-2008, 12:19 AM I have a 95 Z34 the serpentine belt slipped off. I am trying to replace the idler/tension pulley but it will not line up properly. Does anyone have any tricks? its cold outside and Ive been trying for two days PLEASE HELP !! jgblast 01-26-2008, 09:21 PM i just went through that problem with idler tension pully i was working with the wrong bolt that held the old one in never would tighten up correctly fixed problwm by using a allen head bolt more narrow j cAT 01-27-2008, 04:30 PM I have a 95 Z34 the serpentine belt slipped off. I am trying to replace the idler/tension pulley but it will not line up properly. Does anyone have any tricks? its cold outside and Ive been trying for two days PLEASE HELP !! if your belt fell off your tensioner is bad or your belt is wrong. if you replaced belt check that old and new are the same length.......insuffient tension or idler out of position will cause your problem no tricks here..... Automotive Network, Inc., Copyright ©2012
