Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-21-2008, 09:08 PM   #1
usfourangels
usfourangels Normal reputation
1990 Toyota Camry LE Driver side window and power locks?
I just purchased a 1990 Toyota Camry LE for my daughter and the first time we put the driver side window down it wouldn't go back up. My husband finally got it forced back up, but now we have noticed that the power door locks don't work either. When the door is opened and moved back and forth we noticed that the lights on the window controls go on and off so my husband thinks that it is in the the wiring so I have been looking for a wiring harness for the driver side door and I am not able to find one. Does anyone have and help or advice of what I need to look for? Thank you for any help.
usfourangels is offline   Reply With Quote
Old 01-22-2008, 01:53 PM   #2
Mike Gerber
AF -Advisor
Mike Gerber Normal reputation
Re: 1990 Toyota Camry LE Driver side window and power locks?
The loom of wires leading in to the door by the front hinge is usually the problem area. That loom is subjected to a lot of flexing over the years, as the door is constantly opened and closed. Try opening up that loom of wires and looking for frayed or broken wires. If you don't have a wiring diagram, try moving the wires around individually until you find 1 or 2 that are broken as indicated either by feel or by the lights on that panel flickering on and off.
Mike
Mike Gerber is offline   Reply With Quote
Old 01-22-2008, 04:31 PM   #3
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
I just replaced the wiring harness for my '92 driver side front door after 198k miles and a nonfunctional rear left window...oddly saw at least 4 broken or nearly broken wires when I dissected the old one but just happenede to maintain contact.
You might be able to get some contact by rolling/pinching the harness at the bend (the part with the rubber boot, nearest the body) betwen your fingers. If that gives you intermittent power while operating the switches, then that's your culprit.
Replacement isn't too hard, just be careful removing the bottom part of the door panel so the metal anchors don't pull out of the fiberboard panel backing.
I found a used replacement at the salvage yard for $50 but inspected underneath the rubber boot before installing it. Sure enough it had fatigued as well but no wire breaks, just broken insulation. I taped up each wire and then wrapped more electrical tape around the portion that sees the most fatigue (for more reinforcement) and slid the boot back in place. Hope this helps!
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 02-12-2008, 04:53 AM   #4
usfourangels
1990 Camry door wiring harness??
Does anyone know a place to locate and purchase a door wiring harness for a '90 Camry LE? I have called the Toyota dealership and they want over $300.00 and I haven't been able to find one at any salvage yards in my area? I am getting desperate. I read previous advise about others just fixing the wires on their own, but my husband said that the boot is bad and the wires have been repaired so many times that they would just break again so not an option. Any help would be appreciated. Trying to locate this part has become so very frustrating!!!!
Old 02-12-2008, 12:53 PM   #5
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
Re: 1990 Camry door wiring harness??
Perhaps you could adapt a wiring harness from a more recent model that is more easily found. Extra wires/connectors are not a big deal....
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 02-12-2008, 01:14 PM   #6
usfourangels
Would you know what year Camry would be similar enough to the 90 Camry that we would be able to use the harness? Or what one would be similar enough? Thank you for replying.
Old 02-12-2008, 06:09 PM   #7
Mike Gerber
AF -Advisor
Do a Google search for "Toyota salvage yards". There are several that specialize in just Toyotas. I believe one was in Texas. Sorry I can't remember the name.
Mike
Old 02-12-2008, 06:17 PM   #8
Brian R.
Resident Chemist
Brian R.'s Avatar
Sorry, no. I don't do wiring. But if you could get one from a 3rd gen, you can see if the same type of connector is used on each end of the harness. That would be the most important characteristic. I don't believe that the current draw of the motors and lights changed very much.
FWIW, please don't start new threads related to the same topic as an existing thread. I have combined your two threads on this topic.
Old 02-13-2008, 01:03 PM   #9
somick
somick's Avatar
somick Normal reputation
Finding a harness that fits exactly is, of course, the better choice. But if no luck on that I would create one of my own. Put new wires through the old boot and make splices inside the cabin on one side and inside the door on another side. That what I did on my old Chevy years ago and it worked till it got totaled.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 02-13-2008, 01:47 PM   #10
GSS123
GSS123 Normal reputation
This company will build you a harness but will need your old one for a model. http://www.agexpress.com/
Call them first to discuss your project. They've done RV's and large farm tractor electrical harnesses for me.
GSS123 is offline   Reply With Quote
Old 02-15-2008, 12:24 PM   #11
jdmccright
The RustBuster
jdmccright's Avatar
As somick suggested, you can replace the broken wires by splicing in new wire pieces. Make the splice lengths abt 4-6" and terminate them well away from the bend site. I would also stagger the splice locations along the harness to prevent it from getting too fat to fit through the rubber boot. Stick with the same gauge and strand number/thickness. Fewer but thicker strands in a same-gauge wire won't hold up as well as those with more and thinner strands. Soldered connections are better than crimped or twisted and shrink tubing is better and cleaner than vinyl electrical tape for insulating the splice sites.
It'll take some patience, but it can be done.
Current Garage:
Vehicle History:
1996 GMC Jimmy 4wd
1980 Yamaha XS400
Bookmarks
Google
Web AF
