Ford Escort 93 electrical drain
Hi!
I have had my Ford Escort for about 3 years and it has always been good to me until a couple of months ago when the battery started draining very quickly making me jump start it a lot.
I think I have found the problem area but I want to be sure since I am new to electrical stuff. Here is what I have done:
I had the battery checked out (it is new) and it is in good condition. I unhooked the ground to my battery and put my multimeter in putting it on the '10A' setting. It gave me a .18 reading which I am not sure if that is good or not so I started taking fuses out until I got it to read 0.0. I found that the 'Room' Fuse under the steering wheel when removed placed my reading at 0. I looked in the owners manual to see that what it controlled and it says this:
"Dome & map lamp, TWS unit, IG key illumination, luggage lamp, vanity mirror lamp, radio (memory), door lock relay, shift-lock system, EAT module, EEC module"
The only thing I knew how to check from there was the radio and that wasn't it. Is my process right? Can someone clue me in to other things to check? Or do I need to go get one of those batterybrain (batterybrain.com) things and give up?
Help! and Thanks!
