2001 windstar speedometer and abs light prob
ymmotman
01-15-2008, 01:15 PM
i have a 01 windstar lx and just a few day ago all of these came on at once
ABS LIGHT ON
E BRAKE INDICATOR LIGHT ON
O/D LIGHT FLASHING
SPEEDOMETER NOT WORKING
ODOMETER NOT WORKING
other than that everything is working great...lol
any help in this matter would be grearty appricated
mtsav8or
01-15-2008, 02:42 PM
ymmotman (http://www.automotiveforums.com/vbulletin/member.php?u=551947), you should read wiswind's posts at the beginning of the forum. You're problem is listed there. If you check under your master cylinder, you'll find a pressure switch that is most likely leaking. Replace that switch and clean up the old brake fluid and electrical connections that got fluid on them. Afterwards, check your fuses, I don't remember which one but if you do a search or read the posts at the beginning, you'll find better directions than these. I used them step-by-step and was able to save myself a hefty dealer shop repair bill. vbmenu_register("postmenu_5603772", true);
mtsav8or
01-15-2008, 02:44 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=681061
garync1
01-15-2008, 03:55 PM
I have a 2001 that does this from time to time. So far the only thing i found is if the brake fluid get low the E brake light will come on.Some times both like you have. But seeing that you are having problems with your VSS they all could be related. the Speed sensor is tied into seepdo along with the ABS. hope this helps.
ymmotman
01-15-2008, 04:12 PM
would replacing the speed sensor fix this prob or would it be more than that...one mechanic at the local ford dealership seems to think it could be a faulty instrument cluster...does this sound like a good solution and has antone herd of an instrument cluster going in a windstar
garync1
01-15-2008, 08:13 PM
does everything on the cluster work. Except the speed-o. Did this mechanic look at the van.? 1. The E brake and ABS light on the same time is a common problem. It's even listed with the NTSB complaint. The funny thing is until it stays on all the time and code can be read there no solution for it. Now If i turn my van off and restart the van it goes back to normal.. Now if your lights are staying on and your speed-o is not working I would let the dealer run a check with there ABS code reader. Should be around 70.00 bucks But ask for a price first. I have a feeling if all three are giving you problems than it may be the VSS sensor.Check your ABS relay under the hood too make sure it working you can switch with a "like" relay. Hope this helps.
tripletdaddy
01-16-2008, 04:25 AM
Impressive to have all that at once. I too would be suspicious of the VSS, but I don't think it would influence the brakes, not sure. Beside the brake switch under the reservoir possibly being faulty, I've had to really fill the brake reservoir to the tippy top to get the light(s) to turn off. Have they ever previously come on before or even just flickered? Can you still use your cruise control? If not, than the brake switch is bad. Could you possibly be having any other unusual symptoms? Another possibility is low voltage due to weak battery/alternator. Let us know what happens.
tomj76
01-16-2008, 10:19 PM
I'm for checking the VSS.
The O/D light defninately flashes when the VSS signal is lost. I had this experience due to a broken VSS electrical connector.
The electronic speedometer definately will not work when the VSS is dead. I don't have the electronic speedometer on my '96, so I have not experienced it first hand, but I'm certain that it gets it's input from the VSS.
The odometer and the speedometer work from the same signal.
However, I am not aware of the ABS did getting any input from the VSS. It could that your model does take VSS input.
'E BRAKE INDICATOR' is actually a warning light for several different brake issues, including low brake fluid and engagement of the parking brake. It could be related to the ABS light.
Unfortunately the VSS is difficult to get to on my '96. It would be worth it to get your codes read before taking that route. There was a VSS code when my connector fell off.
garync1
01-18-2008, 09:57 AM
From what I understand on most ABS systems where VSS is on. The VSS sends a signal on what speed the whole car is running and the wheel sensors are for each wheel speed. Then the ABS control mod. sends info on how much braking is needed for each wheel. "When ABS is needed" So I am thinking VSS should be linked. I could be wrong. I do know my 2001 has a VSS.. So I would think it would be tied in as well. I also know VSS are used on Cars with out ABS as a basic drive by wire type speedo. So there is no speedo cable.
But anyway if you have an ABS light on it is just easier to take to the dealer or a shop with a ABS scanner to find out whats wrong. Then you can go from there if you want to replace the part your self.
tomj76
01-21-2008, 11:17 PM
It makes sense that the ABS computer would take VSS information, but when I checked my '96 service manual, I could not find a direct connection from the VSS. However, I did confirm that is one to the PCM and one to the cruise control module.
garync1
01-22-2008, 10:31 AM
I understand where you are coming from but does your 96 have 4 wheel ABS or 2. My 96 Taurus had rear wheel ABS. So it was not as complex as the 4 wheel. It just was there to keep the rear wheels from locking. Like earlier trucks and cars had. But also I am not confirming his VSS is bad but a direction to look at. I know a lot of newer cars with ABS are tied into the VSS now. I can't confirm this on the 2001. An ABS scan tool would be able to solve this one if the ABS light is still on.
tomj76
01-22-2008, 12:17 PM
The '96 has four wheel ABS.
When the VSS connector came loose, the powertrain behaved badly, particularly the shift patterns of the automatic transmision. Prior to that symptom appearing, the O/D light would blink (at times) and the cruise control would disengage spontaneously. Reconnecting it curred those problems.
garync1
01-23-2008, 08:10 AM
Thanks for the info. I am thinking now Ford may have not added the VSS to the loop for the ABS. I have taken an ABS class and VSS are tied into some cars so I assumed it was part of Ford as well. I know it does make the trans act funny. So Ford I guess still kept the ABS some what simple. I wonder if trac control equipped differs though..??
I do have the same problem time to time my E brake light and ABS light come on. After I turn off the van and restart I might not see it for another month or so.
moin66
02-15-2008, 08:04 AM
I have the same problem as ymmotman. Just wondering if replacing the brake pressure switch and cleaning the contacts etc. solved the problem?
Update: I took the car to the dealership. They think it is the ECU - parts and labor $675. Is that the appropriate price.
ed5
02-14-2009, 08:37 AM
I have this same problem on my 2001. The main point to note is that all lamps ajoined to circuits in question are routed through fuse 10! I believe brake fluid leaked into the break pressure switch which is connected to pin 9 on the cruise control mod and fried into gnd pin 10 burning out the cruise module aka speed control servo. Also routed through f10, you have the instrument cluster, shift lock actuator, blend door acuator for the heater,the fancy stuff on the SEL, the ABS, brake pressure switch, and the A/C clutch. I was wondering why Ford left like 8 empty fuse locations.
carruzo444
12-20-2009, 01:56 PM
I have a 2003 3.8 liter. all these lights came on so I applied a OBD II scanner which gave me code PO720 VSS ( vehicle speed sensor ) this regulates transmission speed with drive axle, motor speed and the odometer. I spent several weeks without doing anything until the drive axle broke. leaving the transmission in what is called neutral "non functional". I change speed sensor and installed new drive axle. windstar is now working great.
A OBD II scan is the best option when having problems with any Ford 1996 and later.
tacomabobd
08-26-2010, 06:24 PM
Guys I am at a loss. What is the O/D light and where is it?
Bob
mtsav8or
08-27-2010, 07:39 AM
The O/D light is on your instrument cluster. If you've got a button in your shift arm, when you press it to take the transmission out of overdrive for hauling heavy loads, the O/D light off comes on the dash to alert you.
When there are problems with the transmission not making enough line pressure or too much as well as some electronic issues, the O/D light will flash and then stay on. It happened on mine after it was rebuilt causing several trips to the tranny shop. After removing it 3 times, and having the computer flashed twice, they got it resolved. 6 months later it started pumping fluid out the front tranny seal and had to be taken out again, and the seal and torque converter were replaced. The light flashed then too. Only a transmission shop or the dealer can really analyze what's going on though. My OBDII scanner was worthless when this happened.
Hognewbie
05-11-2011, 10:44 AM
I had the same sort of issue. After I bought a 2001 Windstar the abs/brake lights started coming on occasionly then about a month later the tranny went out.
Took it to AAmco they replaced both the tranny and torque converter. Now I started having the OD off light coming on. Think has been going on for over a year. Every time I take it back they run the codes and it comes back as a torque converter clutch error. They have already replaced the tranny and torque converter twice and still can't find the issue.
Did you ever get yours resolved?
mtsav8or
05-11-2011, 11:02 AM
Yes, it's been resolved for 2 years now. They ended up putting a shift kit in it and they also had to flash the computer twice too.
Mine still shifted fine, TQ locked up fine, it just had a blinking light. I think other shops probably would have given me the run around but they stuck with it until it was fixed. I'm not in love with the way the transmission shifts and it hunts around when going up the hill and making throttle changes. I'm not sure if that's due to the shift kit or the computer but it's different from stock and not to my liking.
I've got about 80K on the tranny rebuild now so knock on wood, I've been pretty lucky.
