Trans Lock Up Converterpatrari 01-14-2008, 10:03 PM Hello I have a 93 gmc 4x4 1ton 7.4 with a 4l80e and my lock up convertor locks up intermitily while at cruising speeds 65 70. I will be going along and it will lockup and unlock for a split second. Any idea how to trouble shoot this to figure out what is causeing this. Other wise the trans works like it should. 2000CAYukon 01-15-2008, 02:51 AM patrari 01-15-2008, 11:22 AM Is there any way you coyuld give me more info on this? and if you can can u explain it to me please and thank you. went to website thanks maxwedge 01-15-2008, 01:35 PM The pcm controls the application of the tcc based on tps, speed and engine load inputs, the valve body issue may not apply to your year. A full scan will look at whether the listed functions are within operating range, an improperly adjusted stop lite switch could cause this also. Automotive Network, Inc., Copyright ©2012
