violent shake at 55-65 mph!!!!!!!!- ciera cutlassbig_bubbax 01-14-2008, 06:12 PM my 94 ciera cutlass(3.1L) started shaking really bad when im on the highway cruising at 55-65 mph, it has also lossed alot of power since it started happening. it started with it happening once in a while, and just got worse after that to the point that it does it everytime u get up to speed and when u stay between 55-65 mph but if ur going faster or slower u cant notice it as much. i need help with this bad!!! xeroinfinity 01-14-2008, 06:55 PM Welcome to AF. Has it been snowing where you are ? If ice/snow is inside the rim it can cause this shaking due to being off balance. If that's not the case, then your tire could be out of balance or a busted belt, you could have a bent rim. Hope that helps! big_bubbax 01-15-2008, 06:50 PM i know its not anything to do with the wheels some one told me that it could be the lock up solenoid but im not sure cause it has never stalled when im stopping it gets real quiet when i do though. it also has a miss fire and i replaced the egr, maf, the coil and the plugs and wires and i still can figure out the miss fire!!!! xeroinfinity 01-15-2008, 09:25 PM Could be the trany. Get it scanned at a transmission shop Or somewhere that can scan for trans codes. If it's the tcc , it would show a code. on the misfire, get the Ignition control module tested. big_bubbax 01-25-2008, 02:52 PM see thats one of the problems with scaning it, ive tried it with 3 different scaners and each time none of them can even read anything it just comes up with an error it sucks, but i will check out ignition control module 98xploder 01-27-2008, 04:47 AM check the injectors. thats a common cause of misfires yet often overlooked. xeroinfinity 01-27-2008, 01:23 PM see thats one of the problems with scaning it, ive tried it with 3 different scaners and each time none of them can even read anything it just comes up with an error it sucks, but i will check out ignition control module What was it scanned with, a free scan at your local auto store ? They wont show anything that would be trans or ABS related, thier scan tools realy suck and dont show much of anything. You'd need a trans & ABS capable scan tool. Also a misfire wont cause your car to shake violently at highway speeds. 98xploder 01-27-2008, 06:48 PM i never said it would cause the shaking, its clearly a seperate problem. im just stating a common cause of one of the issues at hand. ;) HotZ28 01-27-2008, 07:15 PM my 94 ciera cutlass(3.1L) started shaking really bad when im on the highway cruising at 55-65 mph, it has also lossed alot of power since it started happening. it started with it happening once in a while, and just got worse after that to the point that it does it everytime u get up to speed and when u stay between 55-65 mph but if ur going faster or slower u cant notice it as much. i need help with this bad!!! I think we need a better definition of what “shaking” is here. Is it tire shake, (suspension) or engine shake? This makes a big difference! Chambers000 01-31-2010, 01:47 AM up have same problem, no misfire though, guessing it is the tranny, for me only happens >55mph and when im maintaining speed when accelerating or decelerating no probelms? any thoughtst? the shaking is more of the car really i can feel it under my feet for the most part but everything is shaking. Automotive Network, Inc., Copyright ©2012
