1980 cutlass 3.8 cant get started
97 silverbullet
01-14-2008, 11:07 AM
ok I have the car put together. I have the dizzy hooked up and I made sure all the plugs when to the right cylinders. No im not getting any spark, Im def getting fuel I can smell it and see it shoot up from the carb. Any Ideas? I just recently replaced the timing cover gasket, fuel pump gasket, and oil pan gasket.
xeroinfinity
01-14-2008, 06:33 PM
How about the wires to the dist, are they cracked ?
Not the plug wires, the ones out the side of the dist.
Did you connect the vac advance vacum line ?
97 silverbullet
01-14-2008, 09:48 PM
its a possibility its like 28 years old
Slade901
01-14-2008, 10:15 PM
Make sure you have spark from the coil itself first. I suggested to get a spark tester (the one with alligator clip to connect on a ground). Leave the plug wires from the coil but on the other end of the plug wire must be connect to the spark tester which is clamped on the metal ground. Start the vehicle and see if you have spark.
If you have spark the problem lies somewhere in the distributor.
xeroinfinity
01-15-2008, 09:40 PM
The pick-up coil is inside the distributor, and the coil sets atop of the dist. cap.
That was why I mentioned the wires coming from the dist., they are easy to damage while working up front.
Checking for spark , and checking that the plugs are not soaked and flooded. :2cents:
