Struts Need Replacing Need Info Installbrock02 01-13-2008, 03:33 AM :eek7:MY 94 OLDS needs Struts Is That Something I Could Do Or Is It To Dangerous And Need Expert To do It i`m Some What On A buget G.A.S. 01-13-2008, 04:21 AM You can remove them from the vehical yourself, but I would highly recomend that you have a shop use a spring compressor to put together and dissasembile the strut assy. should be three nuts to remove on the top of the strut and two on the bottom. Now comes the alignment part. any time struts are replaced an alingment needs to be done. xeroinfinity 01-13-2008, 11:41 AM Welcome to AF brock02. You can rent a spring compressor , it's not that hard as long as safety is taken and you follow the directions to a "T". A manual would help you out too (http://www.autozone.com/az/cds/en_us/0900823d/80/0e/df/7c/0900823d800edf7c/repairInfoPages.htm). ;) And an alignment is necessary. Good Luck Automotive Network, Inc., Copyright ©2012
