Re: wiper problem
I think our 92 Escort has a 16" or 17"' blade on the short side, a 20" on the long side. Even so, if they touch its an indication one of the arms is mounted on the pivot at the wrong angle. It may have gotten skewed if someone turned on the wipers when one blade was frozen to the windshield. With a little prying up while holding the arm 'socket' down on the end of the pivot, I think the arm will slide up and off. The pivot and the inside of the arm are probably splined. If the splines are worn away from the arm, its probably time for a new arm. The non-parking problem would probably be a dirty contact (or covered in hardened grease) inside the little gear case at the end of the motor.
