left head lightnorthwoods60 01-10-2008, 07:39 PM how does one change the halogen bulb? I noted a fuse box just behind the where it would be easy to change the bulb. The owner manual is easy to follow for changing, but its getting to it. help please. catvents 01-10-2008, 08:23 PM how does one change the halogen bulb? I noted a fuse box just behind the where it would be easy to change the bulb. The owner manual is easy to follow for changing, but its getting to it. help please. According to your profile, your Windstar is a 2000. On the top of the light block, you have 2 clips (look like a L); with a small screwdriver you will be able to unlock and pull them up. You will notice that one is longer than the other one. After that, just pry the block from side to side and remove it from the front panel. You have now access to the bulb (9007) lapin_windstar 01-11-2008, 06:39 PM ha ha - don't forget to unplug the lead that attaches to the back of the bulb. I forgot to do this last week and couldn't work out why the whole unit wasn't coming out! :iceslolan Automotive Network, Inc., Copyright ©2012
