2003 Sierra 1500 grease fittingsGMguy83 01-10-2008, 11:20 AM I'm going to start changing my own oil on my truck and was wondering if someone could tell me exactly where all the grease fittings were located underneath. Thanks. wafrederick 01-10-2008, 12:09 PM Probally does not have any if the suspension parts are original.Check your transfercase and both differantals if it is a 4x4 also.Checking the fluids is a must during an oil change and most oil change places do not do this.I have seen this,a burned up transmission and a burned up rear end so far because the oil change place and one dealer did not do this.The transfer case uses special fluid if it is a 4x4,Auto Trak II and it is from the dealer only. Z15 01-10-2008, 12:39 PM There are fitting, upper and lower ball joints (4), tie rods (2), pitman arm (1) with fitting facing up (pita the get to) and the ldler arm (1). I think I covered them all. No wait, I think there is one on the front drive shaft of 4x4's. Automotive Network, Inc., Copyright ©2012
