Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 01-10-2008, 12:18 AM   #1
shawn_dh
shawn_dh Normal reputation
Choke Coil Not Heating Up
I have a 85 S10 Blazer with a Rochester carb. There is an electric choke on this model. It seems like the heating of the coil is speratic. Is there a way to check the voltage going through that wire which connects to the choke? Or do you have any ideas on how to test to see if the correct amount of current is flowing? As a note there is no binding in the linkage and the coil is brand new.
Let me know if you have any other questions.
TIA
shawn_dh is offline   Reply With Quote
Old 01-10-2008, 08:02 AM   #2
16th hippy
16th hippy Normal reputation
Re: Choke Coil Not Heating Up
check it with a DVOM. should have the 12V running through it.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
16th hippy is offline   Reply With Quote
Old 01-10-2008, 10:34 AM   #3
shawn_dh
Thanks for the tips and the info on the voltage. I will check it out.
Old 01-12-2008, 04:39 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Might help to check the schematic, or trace the wire back. Some were set up to only have voltage when the alternator is charging. If that's the case, voltage should be 14.2 volts only present when the engine is running. The circuit was designed that way so if the engine stalled during warm up, the choke would not continue to come off.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
