Location of all fuse panels 95 Jimmy
gypsyhawk
01-09-2008, 06:28 PM
Does anyone happen to know if there is more than one fuse panel on the 1995 Jimmy? We replaced the engine and there is power to the starter and then absolutely nothing. We traced and traced and can't find anything. Battery is fully charged, the fuses in the panel on the drivers side are fine.
Any ideas?:confused:
MT-2500
01-09-2008, 06:40 PM
It has a under dash fuse box.
Is it getting 12 volts power to it?
On it the power feeds to switch and fuse box they should come from the big terminal on back of alternator.
Did you get both big wires bolted back on there on the big terminal?
Check the big terminal on alternator for 12 volt battery power.
If 12 volt power there go to fuse box and ign switch see if it has any 12 volt power there?
Post back what you find and or for more help.
MT
