1994 Water Pump Pulley 2.5LBullitt94 01-08-2008, 04:47 PM I am replacing a water pump on a 2.5L 626 and naturally I bought the pump with the wrong sized pulley mount. Apparently they had a 32mm and a 16mm stub shaft. I needed the 16mm, but have installed the 32mm. Does anyone know if I just buy the 32mm stub shaft pulley will it line up with the other pulleys and work with the same belt? Thank you in advance for your help. Bullitt94 01-13-2008, 10:28 PM This does work, for future reference. You can use either pump as long as you have the matching pulley. I bought the other pulley and everything works great. Automotive Network, Inc., Copyright ©2012
